ISO 9000 is the latest hot topic in marketing and manufacturing circles. Everyone seems to be talking about it, but few seem to understand it completely. depending on whom one talks to, it's either the greatest thing to hit industry since the assembly line, another cash cow for slick consultants, a conspiracy on the part of Europeans to dominate global markets, or the next necessary step to compete in the global economy of the twenty-first century. It may be all of the above.
Another year has passed and, because of the short term ups and downs of the economy, it's still hard to judge whether we are in an appreciably different place than we were a year ago. The economy doesn't seem to be worse than it was, but it also doesn't seem to be a whole lot better.
What can be done about the rising cost of labor? Mr. Robert Reich, U.S. Secretary of Labor, has already indicated the administration's intention of pushing the minimum wage from $4.25 to $4.50 per hour and indexing it for inflation. That means that every jiggle in the inflation chart will push the minimum wage higher.
Forty of Gear Technology's pre-show and show issue advertisers will be exhibiting a wide range of goods and services at AGMA's Gear Expo '93. The exhibition will be held October 10-13 at Cobo Conference & Exhibition Center in Detroit, MI. Below is an alphabetical listing of these advertisers and a preview of what can be seen at their booths.
Putting one's best foot forward is important for successful business communication. And successful business people know the "rule" of the game, what it say and do in business situations, to make the best impression. However, these rules change from country to country, and what is appropriate behavior here may appear rude to someone from Latin America, Europe or Asia To help you become more familiar with some of the different rules of engagement in other countries, Gear Technology spoke with three businessmen who have had extensive contact in various part of the world.
Two items of interest have crossed my desk in the last couple of weeks. One of them is a copy of a speech by Harry E. Figge, Jr., Chairman and CEO of Figge, International Inc., and the other is an article by Peter Brimelow in the July 19, 1993, issue of Forbes. The two items are directly related to one another, the Brimelow article being a response to the points raised in Figge's speech and in much grater detail in his book, Bankruptcy 1995: The Coming Collapse of America and How to Stop It. Both the speech and the response are well worth our attention.
