Five years of effort by AGMA came to fruition in January with the publishing of a report from the Department of Commerce. This "National Security Assessment of the U.S. Gear Industry" indicates that if serious measures are not taken, the gear industry's future is in jeopardy. It also sets the tone for confronting major challenges now looming large in our industry.
Bankruptcy filings have not noticeably declined despite the economic recovery of the Reagan years. Businesses continue to receive notices that their customers have filed bankruptcy. Many of them are writing off significant losses each year as a result. despite the frequent use of bankruptcy by debtors, many business owners and managers have little or no idea of the pot-bankruptcy remedies available to them.
Countless research studies confirm this fact: Companies that advertise aggressively during a recession will flourish after the economic tide turns. Regardless of company size, effective advertising generally requires the services of an agency, and under current economic conditions, you may need one now more than ever. The question is, how do you go about getting the right one for your company.
You get calls and letters every day from people wanting you to use their ad agency, their direct mail program, their p.r. or marketing firm to promote your business. It seems everyone wants you to spend your money to communicate to your prospects and customers. But what's the best method for you?
A study of AGMA 218, the draft ISO standard 6336, and BS 436: 1986 methods for rating gear tooth strength and surface durability for metallic spur and helical gears is presented. A comparison of the standards mainly focuses on fundamental formula and influence factors, such as the load distribution factor, geometry factor, and others. No attempt is made to qualify or judge the standards other than to comment on the facilities or lack of them in each standard reviewed. In Part I a comparison of pitting resistance ratings is made, and in the subsequent issue, Part II will deal with bending stress ratings and comparisons of designs.
Dear Editor:
Your article on the ITC's Report to the President on the condition of the U.S. gear industry (Sept./Oct. issue) was most interesting. I am wondering if the total report neglected to mention that some of our inability to export gears is due to our reluctance to provide metric countries with the metric module-based gears that overseas customers demand.
