"It's show time!" Ready or not, on Sept 3, the biennial International Machine Tool Show opens at McCormick Place, Chicago. Planning a show that encompasses displays from over 1000 companies from 29 nations and an associated technical conference presenting more than 200 papers on 50 topics has not been without its problems.
At the present time, technology seems to be moving faster than our ability to educate people in its utilization. this is particularly true of the manufacturing engineering profession.
October 5-8, 1986 AGMA Fall technical Conference & Gearing Exhibit
September 17-19, 1986 Ohio State University Gear Noise Seminar
November 11-13, 1986 SME Gear Processing and Manufacturing Clinic
November 19-21, 1986 Seminar: Gear System Design for Minimum Noise
The last two months have been both a time of difficulty and of growth for Gear Technology. Unexpectedly, I found myself in the hospital having surgery, and consequently out of commission for several weeks. At the same time, two individuals on our staff lost family members, and most of this period saw us getting ready for this preshow IMTS issue while being seriously short-staffed.
September 3-11 the 1986 International Machine Tool Show, "The World of Manufacturing Technology", will be held at the McCormick Place Exposition Center in Chicago. More that 1000 exhibits from over thirty countries are planned. These exhibits will present a complete range of machine-tool products from 2-story high presses to complete manufacturing systems, lathes, lasers, CAD/CAM systems and robotics.
