It is with great anticipation that we move closer to AGMA's Fall Technical Conference and Gear Expo '87, which is being held on Oct. 4-6 in Cincinnati, OH. This bold undertaking by both AGMA and the exhibitors in the Expo's 160 booths is an attempt to make a major change in the industry's approach to the exposition of gear manufacturing equipment. By combining the Expo with the Fall Technical Conference, those involved in gear manufacturing will have the opportunity to review the latest equipment, trends, and most innovative ideas, while keeping up with the newest technology in the industry.
"Competitiveness" is the newest corporate buzzword. It is being offered as the solution to all our economic problems. Newspapers, magazines and legislation are pushing us to be more "competitive."
In this discussion of gear roll-finishing particular attention is called to the special tooth nomenclature resulting from the interaction between the rolling die teeth and the gear teeth. To eliminate confusion the side of a gear tooth that is in contact with the "approach" side of a rolling die tooth is also considered to be the approach side. The same holds true for the "trail" side. Thus, the side of the gear tooth that is in contact with the trail side of a rolling die is also considered to be the trail side.
The load capacity rating of gears had its beginning in the 18th century at Leiden University when Prof. Pieter van
Musschenbroek systematically tested the wooden teeth of windmill gears, applying the bending strength formula published by Galilei one century earlier. In the next centuries several scientists improved or extended the formula, and recently a Draft International Standard could be presented.
Inviting an American shipbuilding industry official to discuss the subject of meeting foreign competition is like inviting Jackie Gleason to speak on dieting. I am painfully aware of the commercial shipbuilding industry situation. Let me tell you a little about it.
Now that the new tax bill has been passed, the time has come to begin evaluating how it will affect investment strategies in the machine tool business. Your first reaction may be to think that any motivation to invest in capital improvements in your company is gone, because both the investment tax credit and the accelerated depreciation on capital investment have been removed from the tax law. After all, if Uncle Sam is not going to help us out through some short term tax gains, why should we bother? Can we afford to bother?
