Helios Gear Products will debut two state-of-the-art gear manufacturing solutions at the International Manufacturing Technology Show in Chicago, September 12–17, 2022.
Star Cutter Company has announced that it will be continuing its support of Alpena Community College’s manufacturing programs through increased monetary and equipment donations to the college. The donations will be supplied over a two-year period of time, helping to bring state-of-the art manufacturing equipment, such as grinding machines and optical comparators, to the center for hands-on training opportunities.
The fascination of the automotive differential has led to the idea to build a second differential unit around a first center unit. Both units have the same axes around which they rotate with different speeds. The potential of double differentials as ultrahigh reduction speed reducers is significant. Only the tooth-count of the gears in the outer differential unit must be changed in order to achieve ratios between 5 and 80 without a noticeable change of the transmission size.
Nidec Machine Tool (Wixom, Mich.), responding to the needs of the industry, is debuting the new GE15HS gear hobbing machine at IMTS 2022 in Booth #237036. Emphasizing high speed, precision and efficiency, the new machine produces gears for electric and hybrid cars, as well as for robotic and automation applications.
LK Metrology, Inc. will be exhibiting a variety of new products in Booth #135230 in the East Building, Level Three at McCormick Place in Chicago, IL for the 2022 IMTS Show, September 12-17, 2022.
At IMTS 2022, Norton ׀ Saint-Gobain Abrasives (Booth #237042, North Hall) will offer a portfolio of gear grinding products specifically designed by category to provide higher profile accuracy, supreme form holding and burn-free grinding in worm, profile, and bevel applications. Highlighting the range is an innovative dual-worm wheel design that enables two operations in one grinding wheel, substantially saving time and cost.
The L.S. Starrett Company has enhanced its AVR300 Multi-Sensor Vision System with a large 2.36" (60 mm) FOV-dedicated 0.14x telecentric lens for micron-level resolution and accurate field-of-view (FOV) measurements. This is the largest FOV to date for Starrett. IMTS attendees can see the AVR-FOV at Booth #135044 located in the Quality Pavilion, East Hall in McCormick Place, Chicago IL from Sept 12- 17, 2022.
