For the 2014 Orion launch, NASA introduced the Launch Abort System (LAS). This large manifold housing made from 6AL-4V titanium is designed to rapidly propel astronauts away from the main rocket in case of a catastrophic explosion or any other unexpected event. Once fired, the LAS will accelerate the astronauts away from the main rocket at forces up to 10 to 15 times normal gravity (“G’s”). This critical part of the safety system was once again vacuum heat treated by Solar Atmospheres of Western PA for their most recent launch.
To centralize operations and continue to better serve its customers, tooling supplier Ceratizit USA, Inc. has shifted its official U.S. Headquarters from Warren, Michigan, to the company’s Schaumburg, Illinois, facility location. Ceratizit acquired the Schaumburg facility when it absorbed the Komet tooling brand name and product line under the Ceratizit Group umbrella.
Global EDM supplier also moves to new location to enhance production and service capabilities
August 16, 2022
Beaumont Machine is a builder of Electrical Discharge Machines (EDM) for the aerospace, power gen and electronics production industries. Founded by Ed and Tanya Beaumont over 30 years ago, the company was recently repurchased, after the owners had sold the business in early 2013.
Guill Tool, a growing supplier of components to the global aerospace industry, has announced the production of a new internal spline tool made of anodized carbon steel.
DN Solutions (formerly Doosan Machine Tools) recently announced the opening of a Technical Support Office in Troy, Michigan. The new location will provide process improvements and technical solutions to both dealers and customers.
TCI Precision Metals will be showing its precision Machine-Ready Blanks capabilities to customers at IMTS 2022, McCormick Place, Chicago, IL, September 12-17, 2022, West Building, Booth #432123.
With the addition of two new sales engineers in the company’s Midwest Territory, Ceratizit USA looks to continue its double-digit growth while continuing to support and optimize customer tooling and machining processes.
With the recent addition of three new sales engineers and an application specialist, Ceratizit USA has doubled the size of its Eastern Territory sales and support team. In doing so, the company further improves response time and provides added expertise for its customers’ custom tooling challenges.
The new iWire function from GF Machining Solutions automatically identifies and adapts wire speed to changing erosion height conditions during the wire EDM process. This capability eliminates wire breakage while reducing overall wire consumption per job, in some instances by as much as 29 percent.
