Getting rid of personal mementos is an arduous housekeeping ritual for some
of us; every last gear has a memory. One man’s trash is another man’s gold, after all, or in some cases, one failed business is a forgotten piece of personal and mechanical genealogy. Such is the case of the Hill-Climber chainless bicycle, the remains of which were pulled from a family junk pile after nearly half a century.
Today’s ever-evolving global economic engine is, in many ways, a wonderful phenomenon; you know—a rising-tide-lifting-all-boats, trickle-down-theory-of-economics dynamic at work.
An experimental effort has been conducted on an aerospace-quality helical gear train to investigate the thermal behavior of the gear system as many important operational conditions were varied.
