New GRSL technology adds value to high-volume transmission gear inspection by combining non-contact laser inspection with tried-and-true composite roll testing.
More than any other field, IIoT overlaps directly with metrology's mission to analyze and measure as much of the manufacturing process as possible, and it's no surprise that the latter is utilizing the former.
Despite the development and availability of a number of newly engineered, rugged materials intended for plastic gear applications, some engineers/designers continue to believe metal is better.
With increasingly smaller returns from improving the speed of the actual gear grinding process, improving your setup time has become a primary way to keep improving efficiency. Here's the latest on how you can do that today.
Gear Industry Steps Up to Automation
Challenges in Auto Industry. Automotive parts are always moving. They are zipping across conveyors, smashing into each other in bins and traveling across the production chain before ending up inside an automobile. For gears, this can be a somewhat precarious situation as they tend to run best when they're free from nicks, abrasions, cracks or other damages.
Back around 2005-2010, the most exciting things that were happening in broaching had little to do with broaching. What
was happening - and continues to
evolve today - was the emergence of on-the-edge CNC, software and servo drive
technology. Together, they practically
transformed a metalworking process as
old as water into a viable, alternative
consideration for producing high-volume
part runs.
