AGMA's Gear Expo '89, "The Cutting Edge," opens at the David Lawrence Convention Center in Pittsburgh, PA, on Nov. 6 and runs through Nov. 8. This year's show is "the largest trade show ever conceived specifically for the gear industry," according to Rick Norment, AGMA's executive director. The show is 60% larger in terms of floor space than the 1987 show, and over 90%of the booths have been sold.
How important is the right choice of coupling in determining successful machine design? Consider the following
example. A transmission of appropriate size was needed to transfer the speed of the engine driver to that of the driven generator. The transmission was properly selected and sized to endure the rated power requirements indefinitely, but after only a short time in operation, it failed anyway. What happened? The culprit in the case was a coupling. It provided the necessary power and protection against misalignment but it lacked the ability to isolate the gears from the torque
peaks of the diesel engine.
Noisy gear trains have been a common problem for gear designers for a long time. With the demands for smaller gear boxes transmitting more power at higher
rpms and incumbent demands for greater efficiency, gear engineers are always searching for new ways to reduce vibration and limit noise without increasing costs.
the same heat of material
A gear can be defined as a toothed wheel which, when meshed with another toothed wheel with similar configuration, will transmit rotation from one shaft to another. Depending upon the type and accuracy of motion desired, the gears and the profiles of the gear teeth can be of almost any form.
