It takes confidence to be the first to invest in new manufacturing technology. But the payback can be significant. That has been the experience at the Ford Motor Company's Transmission & Chassis Division plant at Indianapolis, IN, which boasts the world's first production application of dry hobbing.
Standards are unlike gears themselves: mundane, but complex, ubiquitous and absolutely vital. Standards are a lingua franca, providing a common language with reference points for evaluating product reliability and performance for manufacturers and users. The standards development process provides a scientific forum for discussion of product design, materials and applications, which can lead to product improvement. Standards can also be a powerful marketing tool for either penetrating new markets or protecting established ones.
The International Manufacturing Technology Show provided one of the biggest ever marketplaces for buying and selling gear-making equipment, with 121601 attenders, making it the largest IMTS ever. The show took place September 4-11 at McCormick Place in Chicago, IL.
IMTS: It can be the best of times or the worst of times. The best because nowhere will you find more equipment, products and services for your business than at McCormick Place, Chicago, in September; the worst because finding your way around the show and around the city can be a hassle.
Zero to 125 MPH in five seconds. Maximum speed of 211 MPH. Seven-second pit stops. Formula One racing is a high-adrenalin sport - one which demands peak performance from drivers and machines alike.
The capabilities and limitations of manufacturing gears by conventional means are well-known and thoroughly documented. In the search to enhance or otherwise improve the gear-making process, manufacturing methods have extended beyond chip-cutting - hobbing, broaching, shaping, shaving, grinding, etc. and their inherent limitations based on cutting selection and speed, feed rates, chip thickness per tooth, cutting pressure, cutter deflection, chatter, surface finish, material hardness, machine rigidity, tooling, setup and other items.
The heat treating of gears presents a difficult challenge to both the heat treater and the gear manufacturer. The number and variety of variables involved in the manufacturing process itself and the subsequent heat treating cycle create a complex matrix of factors which need to be controlled in order to produce a quality product. A heat treater specializing in gears or a gear manufacturer doing his own heat treating must have a clear understanding of these issues in order to deliver a quality product and make a profit at the same time. The situation also presents a number of areas that could benefit greatly from continued research and development.
