A gear is nothing without its counterparts. Gears work in conjunction with other components within a gear system to achieve specific mechanical functions. These counterparts work together synergistically to form functional gear assemblies capable of transmitting motion and torque, converting speed and torque ratios, and performing a wide range of mechanical tasks in various applications across industries.
For wind turbine main gearboxes (MGBs) with about 1 MW or higher power, gearbox designs with multiple power paths are used. They handle several mega-Newton-meter of torque economically. Earlier wind turbines with lower power ratings used parallel shaft gearboxes with only one power path but soon they were superseded by planetary gearboxes having typically three to five planets per stage. This paper describes experiences using planetary gears where “Flexpins” are used to improve the load sharing between the individual planets—representing the multitude of power paths—and along the planet’s face width.
This paper shows a methodology to extensively evaluate different designs of epicyclic gear systems. As outlined, no choice is required on the part of the designer who is free to probe all design variables.
The main objective of this study is to perform an experimental evaluation of the structural model of a five-planet first planetary stage from a modern 6MW wind turbine gearbox.
The objective of this paper is to develop a method for the algorithm-based design and optimization of the macrogeometry of stepped planetary gear stages.
This study deals with the modeling and consideration of misalignments in planetary gearboxes in the optimization and design process. Procedures for taking into account misalignments in cylindrical gearboxes are standardized and established in industry. Misalignments of central elements like carrier, sun gear or ring gear in planetary gearboxes, cause varying contact positions and variable loads, depending on the angular position of the central elements. This load, which is variable over the circumference, is not taken into account in the standardized procedures, despite its effects on the loads on the gears.
In the wind power industry, the reliability of powertrain components plays a major role. Especially in multi-megawatt offshore applications, an unplanned replacement of drivetrain
components can lead to extremely high costs. Hence, the expectation of wind farm operators is to forecast the system reliability. Under the leadership of the VDMA (Mechanical Engineering Industry Association), the standardization paper 23904 "Reliability Assessment for Wind Turbines" was published in October 2019.
