Recently, there has been increased interest in the dynamic effects in gear systems. This interest is stimulated by demands for stronger, higher speed, improved performance, and longer-lived systems. This in turn had stimulated numerous research efforts directed toward understanding gear dynamic phenomena. However, many aspects of gear dynamics are still not satisfactorily understood.
We need a method to analyze cumulative fatigue damage to specify and to design gear drives which will operate under varying load. Since load is seldom constant, most applications need this analysis.
This article discusses an application driven approach to the computer-aided sizing of spur gear teeth. The methodology is bases on the index of tooth loading and environment of application of the gear. It employs handbook knowledge and empirical information to facilitate the design process for a novice. Results show that the approach is in agreement with the textbook data. However, this technique requires less expert knowledge to arrive at the conclusion. The methodology has been successfully implemented as a gear tooth sizing module of a parallel axis gear drive expert system.
From tiny beginnings, the AGMA Gear Expo is growing into a fine, strapping show. This year's effort, Gear Expo '89, "The Cutting Edge," will be bigger and better than ever. What started as a few tabletop exhibits in Chicago four years ago has now grown to a full-size, international exhibition at the David Lawrence Convention Center in Pittsburgh. With over 160 exhibitors, including major gear manufacturers and suppliers from around the world, this year's show promises to be a great success as well.
In the lubrication and cooling of gear teeth a variety of oil jet lubrication schemes is sometimes used. A method commonly used is a low pressure, low velocity oil jet directed at the ingoing mesh of the gears, as was analyzed in Reference 1. Sometimes an oil jet is directed at the outgoing mesh at low pressures. It was shown in Reference 2 that the out-of-mesh lubrication method provides a minimal impingement depth and low cooling of the gears because of the short fling-off time and fling-off angle.(3) In References 4 and 5 it was shown that a radially directed oil jet near the out-of-mesh position with the right oil pressure was the method that provided the best impingement depth.
The first part of this article describes the analytical design method developed by the author to evaluate the load capacity of worm gears.
The second part gives a short description of the experimental program and testing resources being used at CETIM to check the basic assumptions of the analytical method; and to determine on gears and test wheels the surface pressure endurance limits of materials that can be used for worm gears.
The end of the article compares the results yielded by direct application of the method and test results.
AGMA's Gear Expo '89, "The Cutting Edge," opens at the David Lawrence Convention Center in Pittsburgh, PA, on Nov. 6 and runs through Nov. 8. This year's show is "the largest trade show ever conceived specifically for the gear industry," according to Rick Norment, AGMA's executive director. The show is 60% larger in terms of floor space than the 1987 show, and over 90%of the booths have been sold.
May 18-21. AGMA Annual Meeting, "The Changing World of Gears." Loews Ventana Canyon Resort, Tucson, AZ.
July 12-14, 1989. ASM international Conference on Carburizing. Sheraton Hotel & Conference Center, Lakewood, CO.
September 12-20, 1989. European Machine Tool Show, Hannover, West Germany.
How dynamic load affects the pitting fatigue life of external spur gears was predicted by using NASA computer program TELSGE. TELSGE was modified to include an improved gear tooth stiffness model, a stiffness-dynamic load iteration scheme and a pitting-fatigue-life prediction analysis for a gear mesh. The analysis used the NASA gear life model developed by Coy, methods of probability and statistics and gear tooth dynamic loads to predict life. In general, gear life predictions based on dynamic loads differed significantly from those based on static loads, with the predictions being strongly influenced by the maximum dynamic load during contact.
