Technical Planetary Gears
A Logical Procedure To Determine Initial Gear Size
When a gear set is to be designed for a new application, the minimum size gears with the required capacity are desired. These gears must be capable of meeting the power, speed, ratio, life, and reliability requirements.
This article appeared in the November/December 1986 issue.
