Design Power Loss Lubrication Lubricants The Gear Industry History Technical
A Model of the Pumping Action Between the Teeth of High-Speed Spur and Helical Gears
For a high-speed gearbox, an important part of power losses is due to the mesh. A global estimation is not possible and an analytical approach is necessary with evaluations of three different origins of power losses: friction in mesh contact, gear windage and pumping effect between teeth.
This article appeared in the May/June 2004 issue.
