Super-reduction hypoid gears (SRH) are
bevel worm gears with certain differences regarding hypoid gears. If two axes are positioned in space and the task is to transmit motion and torque between them using some kind of gears with a ratio above 5 and even
higher than 50, the following cases are commonly known. Tribology Aspects in Angular Transmission Systems, Part VIII.
