Home » The Effect of Reverse Hobbing at a High Speed
March 1, 1987
Today it is common practice when
climb hobbing to keep the direction of
the hob thread the same as that of the
helical gear. The same generalization
holds true for the mass production of
gears for automobiles. It is the authors' opinion, however, that conventional hobbing with a reverse-handed hob is more effective for the high-speed manufacture of comparatively small module gears for automobiles. The authors have proven both experimentally and theoretically that reverse-handed conventional hobbing, using a multi-thread hob with a smaller diameter is very effective for lengthening the life of the hob and for increasing cutting efficiency at high speeds.
