Design Crowning Lead Manufacturing Cutting Tools Hobs Inspection Lead Error Technical Spur Gears
Longitudinal Load Distribution Factor for Straddle- and Overhang-Mounted Spur Gears
A pair of spur gears generally has an effective lead error which is caused, not only by manufacturing and assembling errors, but also by the deformations of shafts, bearings and housings due to the transmitted load. The longitudinal load distribution on a contact line of the teeth of the gears is not uniform because of the effective lead error.
This article appeared in the July/August 1987 issue.
