The FlexxCool Coolant Management System offers an efficient way to manage coolant. By automating the coolant process, customers recover labor hours, increase productivity, and improve quality by eliminating human effort and error.
Automate Manual Processes
Stop lugging buckets of coolant from machine to machine. FlexxCool keeps each machine full and at the correct concentrations automatically, so your team can focus on more valuable tasks than filling coolant.
Keep Target Concentration Consistent
Achieving the correct concentration mix for each individual top-up is impractical to do manually. FlexxCool, using its patented UTC (unique top-up concentration) process, consistently maintains target concentrations.
Enable Lights-Out Machining
Machines cannot truly run unattended if they need to be manually refilled with coolant. With FlexxCool, you can "set it and forget it," and return to a completed job. The automated coolant refill system allows for seamless lights-out machining.
Increase Production
By eliminating the manual task of mixing and delivering coolants, machinists are able to stay on their machines longer, thereby increasing production. Valuable machine downtime that would have added up over time is recovered by automating the coolant process. FlexxCool also supports multiple machines at once, thus rapidly multiplying productivity gains.
Improve Health & Safety
From back strains to rashes to skin irritations, repeatedly lifting heavy buckets or recurring exposure to chemicals can cause injuries. FlexxCool improves workplace safety by eliminating lifting and reducing exposure to potentially harmful chemicals.
Eliminate Coolant Spills
Manually filling CNC machines can cause spills – which can halt production, or worse, cause employees to slip and fall. FlexxCool’s fail-safe features prevent overflows at the sump from happening.
Make Better Parts
Running rich or lean impairs the quality of the parts you produce. Automating your coolant management system with FlexxCool ensures that you’re always at the correct concentration to produce the best parts.
Protect High-Value Resources
Automating a routine task like replacing or topping up coolant daily frees high-value resources to focus on higher-value work.
