Back in the days when our great, great, great, etc., grandaddies were designing gears, one of the most common materials in use was wood. For fairly obvious reasons, we don't see too many wooden gears around anymore. But there are a few.
In the past gear manufacturers have had to rely on hob manufacturers' inspection of individual elements of a hob, such as lead, involute, spacing, and runout. These did not always guarantee correct gears, as contained elements may cause a hob to produce gears beyond tolerance limits.
Dear Editor:
