It’s a brave, new hardware-software world out there. Players in the worldwide gear industry who don’t have plenty of both run the risk of becoming irrelevant—sooner than later.
The first edition of the international calculation method for micropitting—ISO TR 15144–1:2010—was just published
last December. It is the first and only official, international calculation method established for dealing with
micropitting. Years ago, AGMA published a method for the calculation of oil film thickness containing some comments
about micropitting, and the German FVA published a calculation method based on intensive research results. The FVA and the AGMA methods are close to the ISO TR, but the calculation of micropitting safety factors is new.
