The AGMA Aerospace Gearing committee is seeking new committee members to revise AGMA 926-C99, Recommended Practice for Carburized Aerospace Gearing. Specifically, metallurgy and heat-treating experts are needed. This information sheet recommends material case properties, microstructure, processing procedures, and other critical parameters for carburized aerospace gears. Due to the unique requirements of aerospace gearing, such as typically smaller lot sizes, demands for higher precision, and stringent quality requirements, this information sheet aims to provide deeper, aerospace-specific information than other already published metallurgical specifications such as AGMA 923, Metallurgical Specifications for Steel Gearing or AMS2759/7, Carburizing and Heat Treatment of Carburizing Grade Steel Parts.
Where would your business be without standards? Can you imagine if every gear manufacturer used different inspection and rating criteria? Or if you had to re-learn new gear nomenclature for each supplier and customer you talked to? Your costs and lead times would skyrocket whereas your quality and safety would plummet. Standards are the documented set of generally accepted practices, rules, guidelines, and requirements within an industry. They are meant to streamline the process, minimize overall cost and waste while improving quality, reliability, and overall customer satisfaction and fiscal health.
AGMA wants you to be involved in gear standards development. The creation of standards helps drive innovation and increase the market value of gear design and manufacturing—it also promotes international trade and commerce, which in turn fuels more innovation. The AGMA Gear Accuracy committee is in the early planning stages for a comprehensive review, and possible revision, of the standard ANSI/AGMA 2116, Evaluation of Double Flank Testers for Radial Composite Measurement of Gears, and we need your input. Committee meetings are a great place to network and collaborate with experts in the field, broaden your knowledge, capture technical expertise in writing, refine the standards you use and see how your influence helps shape best practices throughout America and around the world.
AGMA is happy to announce the publication of two new documents: AGMA 925-B22, Effect of Tribology and Lubrication on Gear Surface Distress, written by a subcommittee of the AGMA Helical Gear Rating Committee, and, AGMA 943-A22, Tolerances for Spur and Helical Racks, written by the AGMA Gear Accuracy Committee.
