The implementation of powder metal (PM)components in automotive applications increases continuously, in particular for more highly loaded gear components like synchromesh mechanisms. Porosity and frequently inadequate material properties of PM materials currently rule out PM for automobile gears that are subject to high loads. By increasing the density of the sintered gears, the mechanical properties are improved. New and optimized materials designed to allow the production of high-density PM gears by single sintering may change the situation in the future.
When designing a gear set, engineers usually want the teeth of the gear (Ng) and the pinion (Np) in a "hunting" mesh. Such a mesh or combination is defined as one in which the pinion and the gear do not have any common divisor by a prime number. If a mesh is "hunting," then the pinion must make Np x Ng revolutions before the same pinion tooth meshes with the same gear space. It is often easy to determine if a mesh is hunting by first determining if both the pinion and the gear teeth are divisible by 2,3,5,7,etc. (prime numbers). However, in this age of computerization, how does one program the computer to check for hunting teeth? A simple algorithm is shown below.
Cost cutting. It's the aerobics of the 90s for businesses large and small. More than just the latest buzzword or 90-second flash-in-the-panacea, it's a survival technique. Companies that aren't trimming the fat now may not be around in five years to regret that they didn't.
May 18-21. AGMA Annual Meeting, "The Changing World of Gears." Loews Ventana Canyon Resort, Tucson, AZ.
July 12-14, 1989. ASM international Conference on Carburizing. Sheraton Hotel & Conference Center, Lakewood, CO.
September 12-20, 1989. European Machine Tool Show, Hannover, West Germany.
