India is rapidly turning into a global manufacturing hub, thanks to the country’s manufacturing and engineering
capabilities, vast pool of skilled expertise and its size. These qualities offer it a strategic advantage for the manufacturing segment. A large number of international companies in varied
segments have already set up a manufacturing base in India and others are following suit. It only makes sense to bring this industry segment together under one roof to discuss the current
trends and technology prevalent to the marketplace. IPTEX 2012 is scheduled from February 9–11, 2012 at the Bombay Exhibition Center in Mumbai, India.
In November, Gear Technology conducted
an anonymous survey of gear manufacturers. Invitations were sent by e-mail to thousands of individuals around the world. More than 300
individuals responded to the online survey, answering questions about their manufacturing operations and current challenges facing their businesses.
The gear tooth fillet is an area of maximum bending stress concentration. However, its profile is typically less specified in the gear drawing and hardly controlled during gear inspection in comparison with the gear tooth flanks. This paper presents a fillet profile optimization technique for gears with symmetric and asymmetric teeth based on FEA and a random search method. It allows achieving substantial bending stress
reduction in comparison with traditionally designed gears. This bending stress reduction can be traded for higher load capacity, longer lifetime, lower noise and vibration and cost reduction.
