What's new on the Gear Technology website this month? Videos from DMG Mori-Seiki, the latest e-mail newsletter and updates on upcoming events, including the Kapp-Niles Rocky Mountain Gear School.
Induction hardening is widely used in both the automotive and aerospace gear industries to minimize heat treat distortion and obtain favorable compressive residual stresses for improved fatigue performance. The heating process during induction hardening has a significant effect on the quality of the heat-treated parts. However, the quenching process often receives less attention even though it is equally important.
