Gears with an asymmetric involute gear tooth form were analyzed to determine their bending and contact stresses
relative to symmetric involute gear tooth designs, which are representative of helicopter main-drive gears.
One of the most effective methods in solving the edge loading problem due to excess misalignment and deflection in aerospace actuation gearing is to localize tooth-bearing contact by crowning the teeth. Irrespective of the applied load, if the misalignment and/or deflection are large enough to cause the contact area to reduce to zero, the stress becomes large enough to cause failure. The edge loading could cause the teeth to break or pit, but too much crowning may also cause the teeth to pit due to concentrated loading. In this paper, a proposed method to localize the contact bearing area and calculate the contact stress with crowning is presented and demonstrated on some real-life examples
in aerospace actuation systems.
Capitalizing on a burgeoning new
technology where gears are of great import, the gear community gathered en masse at the American Wind Energy
Association’s Windpower Expo 2010.
An offshore jack-up drilling rig is a barge upon which a drilling platform is placed. The barge has legs that can be lowered to the sea floor to support the rig. Then the barge can be “jacked up” out of the water, providing a stable work platform from which to drill for oil and gas. Jack-up drilling rigs were first introduced in the late 1950s. Rack-and- pinion-type jack-up units were introduced soon after that and have dominated the industry ever since.
Easily one of the central issues
affecting U.S. manufacturing is what one might call the exports deficit—the inability of American companies to sell products to, for instance, Asian markets, developing countries and other ports of call—due to what they perceive to be unfair trade agreements and or policies.
Traditionally, gear rating procedures consider manufacturing accuracy in the application of the dynamic factor, but
only indirectly through the load distribution are such errors in the calculation of stresses used in the durability and gear strength equations. This paper discusses how accuracy affects the calculation of stresses and then uses both statistical
design of experiments and Monte Carlo simulation techniques to quantify the effects of different manufacturing and
assembly errors on root and contact stresses.
This paper presents the results of research directed at measuring the total stress in a pair of statically loaded and carburized spur gears. Measurements were made to examine the change in total stress as a function of externally applied load and depth below the surface.
