There are a number of companies
working to change the way broaching is perceived, and over the past 10 years, they’ve incorporated significant
technological changes to make the process more flexible, productive
and accurate.
in this area.
Design innovation, superior engineering properties, high
end-market visibility and sustainability distinguish the winners
of the 2011 Design Excellence awards, the annual powder metallurgy (PM) design competition sponsored by the Metal Powder Industries Federation.
