Non-uniform gear wear changes gear topology and affects the noise performance of a hypoid gear set. The
aggregate results under certain vehicle driving conditions could potentially result in unacceptable vehicle noise performance in a short period of time. This paper presents the effects of gear surface parameters on gear wear and the measurement/testing methods used to quantify the flank wear in laboratory tests.
This presentation is an expansion of a previous study (Ref.1) by the authors
on lapping effects on surface finish and transmission errors. It documents
the effects of the superfinishing process on hypoid gears, surface finish and transmission errors.
