When you have a multi-million-dollar transfer line sitting on the shop floor waiting for gears that might take up to two months to get, you have a costly bottleneck.
It isn't for everyone, but...
This book is written for those among us, with or without a technical background, who have an occasional need to use, purchase or specify gears. The author assumes an audience that is not made up of experienced gear designers, but of people who do need to have a basic understanding of the criteria used by the designer. The subjects covered include not only the gears themselves, but their manufacturing methods, the systems that contain them and the terms used to describe them.
