Gear grinding is one of the most expensive and least understood aspects of gear manufacturing. But with pressures for reduced noise, higher quality and greater efficiency, gear grinding appears to be on the rise.
In today's industrial marketplace, deburring and chamfering are no longer just a matter of cosmetics. The faster speeds at which transmissions run today demand that gear teeth mesh as smoothly and accurately as possible to prevent premature failure. The demand for quieter gears also requires tighter tolerances. New heat treating practices and other secondary gear operations have placed their own set of demands on manufacturers. Companies that can deburr or chamfer to these newer, more stringent specifications - and still keep costs in line - find themselves with a leg up on their competition.
What Is Whisker-Reinforced Ceramic?
Whisker-reinforced ceramic as applied to cutting tool inserts comprises a matrix of aluminum oxide into which approximately 50% by volume of high-purity silicon carbide "whiskers" are randomly dispersed. The "whiskers" are, in fact, single crystals having dimensions of approximately 0.6 microns in diameter x 10-80 microns in length. These "whiskers" have a tensile strength on the order of 1,000,000 psi (690 MPa). The composite material that is the best known and most widely applied using this technology is designated WG-300 and manufactured by the Greenleaf Corporation of Saegertown, PA.
Chicago- Results of recent studies on residual stress in gear hobbing, hobbing without lubricants and heat treating were reported by representatives of INFAC (Instrumented Factory for Gears) at an industry briefing in March of this year.
Gear Technology's bimonthly aberration - gear trivia, humor, weirdness and oddments for the edification and amusement of our readers. Contributions are welcome.
