What is the best tooling to use when hard milling a gear tooth on a 5-axis machining center? And what makes it the best? We have just bought a DMG Mori mono-block and are not getting the finishes at the cycle times we require.
Oil-out conditions, or conditions
in which an aircraft is
operating without any oil in its
gearbox or transmission, are
devastating for an aircraft's
hardware. Even the sturdiest gears
usually can't last 30 minutes under such
conditions before they catastrophically
fail, and the whole system usually follows shortly after. That doesn't leave pilots with a whole lot of time to find a suitable location to land in the case of an oil-out emergency.
