Robots, computers and other signs of high technology abounded at IMTS 94, supporting the claim by many that this was one of the best shows ever. Many of the machines on display had so many robotic attachments and computer gizmos that they looked more like they belonged in some science fiction movie than on the floor of a machine shop.
Question: In the January/February issue of your magazine, we came across the term "electronic gearbox." We have seen this term used elsewhere as well. We understand that this EGB eliminates the change gear in the transmission line, but not how exactly this is done. Could you explain in more detail?
"God is in the details," says the philosopher. What he meant was that on the scale of the universe, it's not just the galaxies, the planets, the mountain ranges, or the major rivers that are important. So are the subatomic particles and the genes. It's the little things that make all the difference.
