It’s happened to most manufacturers at one point or another. A defective
product comes back from a customer in
need of repair. Perhaps a bearing or a
gear drive has failed, and the customer
simply needs a replacement. Upon further
examination, the company realizes it was never one of its products in the
first place, but a fabricated copy that
snuck into the market. The manufacturing
community has been dealing with
counterfeit products for decades, but
used machinery dealers and Internet
shoppers seem to continuously get hit
by scam artists.
Easily one of the central issues
affecting U.S. manufacturing is what one might call the exports deficit—the inability of American companies to sell products to, for instance, Asian markets, developing countries and other ports of call—due to what they perceive to be unfair trade agreements and or policies.
Non-uniform gear wear changes gear topology and affects the noise performance of a hypoid gear set. The
aggregate results under certain vehicle driving conditions could potentially result in unacceptable vehicle noise performance in a short period of time. This paper presents the effects of gear surface parameters on gear wear and the measurement/testing methods used to quantify the flank wear in laboratory tests.
