and macropitting is examined.
The following article is concerned with the analysis of the wear-reducing effect of PVD-coatings in gearings. Standardized test methods are used, which under near-real conditions enable
statements to be made about the different forms of damage and wear (micropitting, macropitting, scuffing).
The market demand for gear manufacturers to transmit higher torques via smaller-sized gear units inevitably leads to the use of case-hardened gears with high manufacturing and surface quality. In order to generate high part quality, there is an increasing trend towards the elimination of the process-induced distortion that occurs during heat treatment by means of subsequent hard finishing.
Design Problem: Develop a gear drive for a pedal-powered water craft that will be easy to manufacture, use and maintain; that will be lightweight enough for the boat to be portable; and that will eliminate the environmental risk of lubricants leaking into the water.
Electroless Nickel (EN) plating, a process dating back to the 1940s, is one of the predominant metal finishing methods today. It is especially suitable for the gear industry, whose end uses span innumerable other industries, providing an endless assortment of requirements, environments, materials and specifications. EN plating has a broad array of functional features, which include:
This article summarizes the development of an improved titanium nitride (TiN) recoating process, which has, when compared to conventional recoat methods, demonstrated tool life increases of up to three times in performance testing of hobs and shaper cutters. This new coating process, called Super TiN, surpasses the performance of standard TiN recoating for machining gear components. Super TiN incorporates stripping, surface preparation, smooth coating techniques and polishing before and after recoating. The combination of these improvements to the recoating process is the key to its performance.
Physical Vapor Deposited (PVD) coatings such as TiN (Titanium nitride) have been a boon for cutting tool manufacturers. They reduce wear and, therefore, extend tool life, which in turn reduces production costs. But PVD coatings are expensive, and when they fail, they cost both time and money, and they causes of the failure are not always readily apparent.
