Might some of you may be tempted to skip IMTS this year? Business is just so-so. You can’t afford to be away from the shop. It will be a waste of time because you don’t have the budget for new machine tools or new technology anyway. You’ve cut back on travel expenses. It’s your wife’s birthday...
