What Is Whisker-Reinforced Ceramic?
Whisker-reinforced ceramic as applied to cutting tool inserts comprises a matrix of aluminum oxide into which approximately 50% by volume of high-purity silicon carbide "whiskers" are randomly dispersed. The "whiskers" are, in fact, single crystals having dimensions of approximately 0.6 microns in diameter x 10-80 microns in length. These "whiskers" have a tensile strength on the order of 1,000,000 psi (690 MPa). The composite material that is the best known and most widely applied using this technology is designated WG-300 and manufactured by the Greenleaf Corporation of Saegertown, PA.
Okay, so you want to make some high quality gears for your customers, and you want to make a profit for your company, but you don't want to make a mess of the environment. What can you do?
Business ethics are like apple pie and motherhood. Few people are willing to come out agin'em. But in reablity, apple pie is full of fat and refined sugar, motherhood is not what it was when June Cleaver ran the kitchen, and business ethics? Well, it's always been easier to talk about them than to actually practice them, and things certainly haven't improved in the last few years.
"Values" is one of he buzzwords we hear everywhere today. Family values. Traditional values. Alternative values. Along with a balanced budget, less government and more fiber in our diets, "values" - and their practical counterparts, "ethics" - are being promoted as one of the simple, obvious solutions to what ails us as a country and as individuals.
Myth No. 1: Oil Is Oil. Using the wrong oil is a common cause of gear failure. Gears require lubricants blended specifically for the application. For example, slow-speed spur gears, high-speed helical gears, hypoid gears and worm gears all require different lubricants. Application parameters, such as operating speeds, transmitted loads, temperature extremes and contamination risks, must be considered when choosing an oil. Using the right oil can improve efficiency and extend gear life.
