Gear Expo '95, scheduled for November 12-15 at the Indiana Convention center in Indianapolis, IN, will attract more exhibitors from a wider array of industries than any previous show, according to the show's sponsor, the American Gear Manufacturers Association.
Myth No. 1: Oil Is Oil. Using the wrong oil is a common cause of gear failure. Gears require lubricants blended specifically for the application. For example, slow-speed spur gears, high-speed helical gears, hypoid gears and worm gears all require different lubricants. Application parameters, such as operating speeds, transmitted loads, temperature extremes and contamination risks, must be considered when choosing an oil. Using the right oil can improve efficiency and extend gear life.
Precise heat treatment plays an essential role in the production of quality carburized gears. Seemingly minor changes in the heat treating process can have significant effects on the quality, expense and production time of a gear, as we will demonstrate using a case study from one of our customer's gears.
Robots, computers and other signs of high technology abounded at IMTS 94, supporting the claim by many that this was one of the best shows ever. Many of the machines on display had so many robotic attachments and computer gizmos that they looked more like they belonged in some science fiction movie than on the floor of a machine shop.
McCormick Place, Chicago. A manufacturer's dream. Acres and acres of machine tools up and running - cutting chips, filling molds, moving material, bending, shaping, smoothing, measuring. Computers, robots and lasers everywhere - George Lucas goes to engineering school. Sounds, light and, most important, over 100,000 people, moving around, taking notes, asking questions and, above all, buying. This was IMTS '94. A heady, if tiring, experience.
