The two candidates in the upcoming presidential election offer two distinctly different approaches
to solving America’s economic problems -- neither of which is likely to be successful
This article provides an overview of the benefits of using psychoacoustic characteristics for describing gear
noise. And with that, human hearing and the most important psychoacoustic values are introduced. Finally, results
of noise tests with different gear sets aree presented. The tests are the basis for a correlation analysis between psychoacoustic values and gear characteristics.
When you graduated from school and made your way into the world, you probably thought you’d learned everything you needed to know to be successful. But those of us who’ve been out in the workforce for some time know that you
never stop learning.
QuesTek Innovations LLC is applying its Materials by Design computational design technology to develop a new
class of high-strength, secondary hardening gear steels that are optimized for high-temperature, low-pressure (i.e., vacuum) carburization. The new alloys offer three different levels of case hardness (with the ability to “dial-in” hardness profiles, including exceptionally high case hardness), and their high core strength, toughness and other properties offer the potential to reduce drivetrain weight or increase power density relative to incumbent alloys such as AISI 9310 or Pyrowear Alloy 53.
Getting rid of personal mementos is an arduous housekeeping ritual for some
of us; every last gear has a memory. One man’s trash is another man’s gold, after all, or in some cases, one failed business is a forgotten piece of personal and mechanical genealogy. Such is the case of the Hill-Climber chainless bicycle, the remains of which were pulled from a family junk pile after nearly half a century.
