Resonant response
Taxes may be one of the only two sure things in life, but that doesn't make them popular. Nobody is happy to pay them, and the bigger the amount due, the unhappier the taxpayer. Conversely, politicians know that coming out in favor of a tax cut is the equivalent of voting for apple pie and motherhood. It's a sure-fire success at the ballot box.
