An offshore jack-up drilling rig is a barge upon which a drilling platform is placed. The barge has legs that can be lowered to the sea floor to support the rig. Then the barge can be “jacked up” out of the water, providing a stable work platform from which to drill for oil and gas. Jack-up drilling rigs were first introduced in the late 1950s. Rack-and- pinion-type jack-up units were introduced soon after that and have dominated the industry ever since.
Gear manufacturers are moving into an era that will see changes in both engineering practices and industry
standards as new end-products evolve. Within the traditional automotive
industry, carbon emission reduction
legislation will drive the need for higher levels of efficiency and growth in electric and hybrid vehicles.
Meanwhile, the fast growing market of wind turbines is already opening up a whole new area of potential for gearbox manufacturers, but this industry is one that will demand reliability, high levels of engineering excellence and precision manufacturing.
QuesTek Innovations LLC is applying its Materials by Design computational design technology to develop a new
class of high-strength, secondary hardening gear steels that are optimized for high-temperature, low-pressure (i.e., vacuum) carburization. The new alloys offer three different levels of case hardness (with the ability to “dial-in” hardness profiles, including exceptionally high case hardness), and their high core strength, toughness and other properties offer the potential to reduce drivetrain weight or increase power density relative to incumbent alloys such as AISI 9310 or Pyrowear Alloy 53.
Many engineers and purchasing agents think it is more expensive to custom design a component or assembly these
days when often customization can save on total costs.
Industrial gear standards have been used to support reliability through the specification of requirements for
design, manufacturing and verification.
The consensus development of an
international wind turbine gearbox
standard is an example where gear
products can be used in reliable
mechanical systems today. This has
been achieved through progressive
changes in gear technology, gear
design methods and the continual
development and refinement of gearbox
standards.
Creating standards for plastic gears calls for a deft touch. The challenge is to set uniform guidelines, yet avoid limiting the creative solutions plastic offers gear designers.
