No one (not even you and I) consistently makes parts with perfect form and dimensions, so we must be able to efficiently check size and shape at many stages in the manufacturing and assembly process to eliminate scrap and rework and improve processes and profits. Automated inspection systems, which are widely used in all kinds of manufacturing operations, provide great efficiencies in checking individual features, but may not be as effective when asked to evaluate an entire part. You need to know why this is true and what you can do to improve your part yields.
I sat down to write this editorial about my father, Harold Goldstein, as he approached his 80th birthday in October. I had meant it to be a celebration of his nearly 65 years in the machine tool business. Unfortunately, on August 26, as I was working on it, my father passed away after a long battle with emphysema. This editorial has now become a memorial as well as a celebration.
Okay. You've been convinced. You've gritted your teeth and decided to spend the money to launch a company Web site. Everybody from your teenage propeller-head to the girl in the mail room and the salesman in the flashy suit who gave you "such a deal" on Web site services has promised that your site will be the best thing that's happened to your business since the advent of CNC machines.
Earlier this year, a relative of mine, Sidney Mandell, tragically passed away. I had the good fortune to serve with Sidney on the Board of Directors and the Executive Committee of the Machinery Dealers National Association (MDNA). Though he started before me, his MDNA career and mine overlapped for about 2 years. As I think back on the many things I learned form him, one of his favorite phrases keeps come to mind: "We walk in the footsteps of those who have gone before us."
One of the current research
