In the past gear manufacturers have had to rely on hob manufacturers' inspection of individual elements of a hob, such as lead, involute, spacing, and runout. These did not always guarantee correct gears, as contained elements may cause a hob to produce gears beyond tolerance limits.
The phenomena of deterioration of surfaces are generally very complex and depend on numerous conditions which include the operating conditions, the type of load applied, the relative speeds of surfaces in contact, the temperature, lubrication, surfaces hardness and roughness, and the compatibility and nature of materials.
To mechanical engineers, the strength of gear teeth is a question of constant recurrence, and although the problem to be solved is quite elementary in character, probably no other question could be raised upon which such a diversity of opinion exists, and in support of which such an array of rules and authorities might be quoted. In 1879, Mr. John H. Cooper, the author of a well-known work on "Belting," made an examination of the subject and found there were then in existence about forty-eight well-established rules for horsepower and working strength, sanctioned by some twenty-four authorities, and differing from each other in extreme causes of 500%. Since then, a number of new rules have been added, but as no rules have been given which take account of the actual tooth forms in common use, and as no attempt has been made to include in any formula the working stress on the material so that the engineer may see at once upon what assumption a given result is based, I trust I may be pardoned for suggesting that a further investigation is necessary or desirable.
The acceptance by discerning customers of passenger cars is dependent upon both the actual noise lever and the subjective noise character.
The subjective noise character itself can contain, among other features, undesirable noise phenomena which become apparent at certain points in the vehicle operating range. One such critical phenomenon is gear rattle, which is mainly present under low speed, high load conditions. Due to changes in the angular velocity of the crankshaft, gear rattle under driving conditions occurs at the unloaded gears and splines.
CNC technology offers new opportunities for the manufacture of bevel gears. While traditionally the purchase of a specific machine at the same time determined a particular production system, CNC technology permits the processing of bevel gears using a wide variety of methods. The ideological dispute between "tapered tooth or parallel depth tooth" and "single indexing or continuous indexing" no longer leads to an irreversible fundamental decision. The systems have instead become penetrable, and with existing CNC machines, it is possible to select this or that system according to factual considerations at a later date.
