When manufacturing powder metal (PM) gears lead crowning is not achievable in the compaction process. This has to be accomplished either by shaving, grinding or honing. Each of these processes has their merits and draw backs. When employing rolling using a roll burnishing machine lead crowning can be accomplished but due to errors in profile a hard finishing operation such as grinding is used by the industry. In this paper a helical PM gear that has sufficient tolerance class after rolling has been tested in a test rig for durability and the wear has been studied.
In order to reduce costs for development and production, the objective in gearbox development and design is to predict running and noise behavior of a gearbox without manufacturing a prototype and running expensive experimental investigations. To achieve this objective, powerful simulation models have to be set up in a first step. Afterwards, those models have to be qualified and compared to experimental investigations. During the investigation procedure of gearboxes, there are two possibilities to evaluate the running and noise behavior: quasi-static and dynamic investigations. In times of engine downsizing, e-mobility and lightweight design, the dynamic excitation behavior is becoming increasingly important.
The aim of the study was to apply such a specialized tooth contact analysis method, well-used within the steel gear community, to a polymer gear application to assess what modifications need be made to these models for them to be applicable to polymer gears.
The usage of modern thrusters allows combining the functions of the drive and the ship rudder in one unit, which are separated in conventional ship propulsion systems. The horizontally oriented propeller is supported in a vertically rotatable nacelle that is mounted underneath the ship's hull. The propeller can directly or indirectly be driven by an electric motor or combustion engine. Direct drive requires the installation of a low-speed electric motor in the nacelle. This present paper concentrates on indirect drives where the driving torque is transferred by bevel gear stages and shafts from the motor to the propeller.
The deformation of the gear teeth due to load conditions may cause premature tooth meshing. This irregular tooth contact causes increased stress on the tooth flank. These adverse effects can be avoided by using defined flank modifications, designed by means of FE-based tooth contact analysis.
Gear hobbing is one of the most productive manufacturing processes for cylindrical gears. The quality of the gears is a result of the tool quality, the precision of the workpiece, tool clamping and kinematics of the machine. The dry gear hobbing process allows machining of gears with a quality according to the DIN standard up to IT 5. To evaluate which gear quality is possible to machine with a given clamping and hob, it is useful to simulate the process in advance.
In several applications like hoisting equipment and cranes, open gears are used to transmit power at rather low speeds (tangential velocity < 1m/s) with lubrication by grease. In consequence those applications have particularities in terms of lubricating conditions and friction involved, pairing of material between pinion and gear wheel, lubricant supply, loading cycles and behavior of materials with significant contact pressure due to lower number of cycles.
