Excessive machine tool vibration during a precision grinding operation can result in poor workpiece quality in the form of chatter, rough finishes, burn, etc. One possible reason for
excessive vibration is directly associated with the relationship
between natural frequencies of a machine tool system and the
operating speed of the grinding wheel spindle.
This paper demonstrates an application of the tooth interior fatigue fracture (TIFF) analysis method, as implemented in SMT's MASTA software, in which loaded tooth contact analysis (LTCA) results from a specialized 3-D contact model have been utilized to determine the load boundary conditions for analysis of tooth flank fracture (TFF).
should be considered.
stress will be discussed.
This paper addresses the lubrication of helical gears - especially
those factors influencing lubricant film thickness and pressure.
Contact between gear teeth is protected by the elastohydrodynamic
lubrication (EHL) mechanism that occurs between nonconforming
contact when pressure is high enough to cause large
increases in lubricant viscosity due to the pressure-viscosity
effect, and changes of component shape due to elastic deflection.
Acting together, these effects lead to oil films that are stiff
enough to separate the contacting surfaces and thus prevent
significant metal-to-metal contact occurring in a well-designed
gear pair.
The increasing demands in the automotive
industry for weight reduction, fuel
efficiency and a reduced carbon footprint need to be addressed urgently. Up until now, widely used conventional steels have lived up to expectations. However, with more stringent emissions standards,
demands on materials are increasing.
Materials are expected to perform better, resulting in a need for increased fatigue strength. A possibility to increase torque
on current generations without design
changes can be achieved by selecting suitable materials.
Gear-loaded tooth contact analysis is an important tool for the design and analysis of gear performance within transmission and driveline systems. Methods for the calculation of tooth contact conditions have been discussed in the literature for many years. It's possible the method you've been using is underestimating transmission error in helical gears. Here's why.
