Below are listed a variety of commonly used constants arranged numerically to permit ease of reference. Wherever an asterisk (*) is shown, the constant is exact as given, it being generally a mathematical constant or one fixed by definition. In cases where the first constant listed is followed by another in parenthesis, the first is the round number generally used, while the second is the more exact value.
The manufacturing process to produce a gear essentially consist of: material selection, blank preshaping, tooth shaping, heat treatment, and final shaping. Only by carefully integrating of the various operations into a complete manufacturing system can an optimum gear be obtained. The final application of the gear will determine what strength characteristics will be required which subsequently determine the material and heat treatments.
shafts.
