shafts.
When designing gears, the engineer is often faced with the problem of selecting the number of teeth in each gear, so that
the gear train will provide a given speed ratio
On gear drives running with pitch line velocities below 0.5 m/s so called slow speed wear is often observed. To solve
some problems, extensive laboratory test work was started 10 years ago. A total of circ. 300,000 h running time on FZG back-to-back test rigs have been run in this speed range.
This paper presents two new techniques for
aligning and maintaining large ring gears. One technique uses lubricant temperature analysis, and the other uses stop action photography.
Calculation of gear tooth flexibility is of interest for at least two reasons: (a) It controls, at least in part, the vibratory properties of a transmission system hence, fatigue resistance and noise: (b) it controls load sharing in multiple tooth contact.
