High speed gearing, operating with low viscosity lubricants, is prone to a failure mode called scoring. In contrast
to the classic failure modes, pitting and breakage, which generally take time to develop, scoring occurs early in the
operation of a gear set and can be the limiting factor in the gear's power capability.
Since the design of involute splines and
their manufacture requires considerable
knowledge, not only of the basic properties of the involute profile, but also of various other elements which affect the spline fit and the sometimes complex principles underlying manufacturing and checking equipment, the question is frequently raised as to why the involute profile is given preference in designing splines over the seemingly simpler straight sided tooth profile.
This article describes a new technique for the size determination of external Involute splines by using a span measuring method. It provides application performance information
demonstrating how this method and its
measurements correlate with the traditional spline ring gage sizing method.
Austempering heat treatments
(austenitizing followed by rapid cooling
to the tempering temperature) have been
applied to nodular irons on an experimental basis for a number of years, but commercial interest in the process has
only recently come to the surface.
The gear hobbing process is a generating type of production operation. For this
reason, the form of the hob tooth is
always different from the form of the
tooth that it produces.
techniques.
