A reader asks: I'd like to know about the different approaches and factors considered while determining the value of Ka in regards to the DIN 3990 and AGMA standards.
Question: I am a gear engineer for a motor manufacturer in China. I am writing about noise generated from cross-helical gear assembly error. I want to learn the relationship between the misalignment (center distance change and cross-angle shift) and transmission error. It is better under the loading and theory conditions. What is the trend of cross-helical gear development (use ZI worm and involute helical gear, point contact)?
A reader asks: We are currently revising our gear standards and tolerances, and a few problems with the new standard AGMA 2002-C16 have arisen. Firstly, the way to calculate the tooth thickness tolerance seems to need a "manufacturing profile shift coefficient" that isn't specified in the standard; neither is another standard referred to for this coefficient. This tolerance on tooth thickness is needed later to calculate the span width as well as the pin diameter. Furthermore, there seems to be no tolerancing on the major and minor diameters of a gear.
I have a query (regarding) calculated gear life values. I would like to understand for what % of gear failures the calculated life is valid? Is it 1-in-100 (1% failure, 99% reliability) or 1-in-one-thousand (0.1% failure)?
What is the relationship between angular backlash and mean or normal backlash, the axial movement of wheel gear, and mean or normal backlash for bevel and hypoid gears?
A reader wants to know: Are profile ground and hobbed globoidal worm sets better than multi-axis CNC generated globoidal worm gear sets for reduction of noise and vibration?
