A reader wonders about gears where the tops of the teeth are the bearing surface, as used in spur gear differentials. Do they require any special construction or processing?
What is the best tooling to use when hard milling a gear tooth on a 5-axis machining center? And what makes it the best? We have just bought a DMG Mori mono-block and are not getting the finishes at the cycle times we require.
Attached photos (Figs. 1-2) show a
bushing to locate one single bore. This
will be used to locate one single bore
diameter of a gear wheel. What is (the
latest) technology for common clamping a
bushing to locate multiple bore diameters
in hobbing?
I make all the double helical gears that go into a gearbox - four
different gears in this unit. If the gear module for the bull gear and the
intermediate gear are the same (these are the two individual gears that
mate), and the gear module for the high-speed pinion and high-speed
gears are the same (these are the other two individual gears that mate
in the gear box as well), is it then possible to just use two hobs in this
setup to make all four gears, since they mate together with each other?
We are currently using a different gear hob for each gear.
In terms of the tooth thickness, should we use the formulation with
respect to normal or transverse coordinate system? When normalizing
this thickness in order to normalize the backlash (backlash parameter),
we should divide by the circular pitch. Thus, when normalizing, should
this circular pitch be defined in the normal or traverse coordinate
system, depending on which formulation has been used? Is the backlash
parameter always defined with respect to the tangential plane or
normal plane for helical gears?
I would appreciate if you could assist with a gear failure (occurring)
after just seven weeks in service, post installation. This driving gear
wheel has been installed in a medium-speed engine with backlash
present at four different positions; with additional backlash checked on
the mating surfaces. All backlash was found within (OEM)-recommended values. Please note included photos - it seems that the crack has started at the root fillet. Any comments would be appreciated.
I would like some instructions for setting the degrees and minutes on a Liebherr
or Barber Colman hob. Our machines use a Vernier scale to match the lead angle
of the cutter to the part to form straight teeth. There is a dispute on how to do
this task, and I wanted insight from another professional.
