With all the advantages of building float into a planetary gear system, what advantages are there to using a carrier in the first place, rather than simply having your planets float in the system?
Question: We manufacture some gears that require an axial face as a datum, as well as locating on the bore for centering. Other gears use only the bore for both axial and radial locating. What type of workholding is appropriate for each type of part? Is
there workholding that will work for both types?
