The authors use data analysis to determine which tolerances have the greatest effect on transmission error, enabling them to make adjustments and reduce production costs.
Inspection of the cutting blades is an important step in the bevel gear manufacture. The proper blade geometry ensures that the desired gear tooth form can be achieved. The accuracy of the process can be compromised when the blade profile consists of several small sections such as protuberance, main profile, top relief and edge radius. Another common obstacle - are outliers which can be caused by dust particles, surface roughness and also floor vibrations during the data acquisition. This paper proposes the methods to
improve the robustness of the inspection process in such cases.
One way to implement the growing performance requirements for transmissions is by optimizing the surface finish of the gearing. In addition to increasing the flank load capacity and the transmittable torque, this also allows for improvements in efficiency. On Oerlikon bevel gear grinding machines from Klingelnberg, fine grinding
can be implemented efficiently in bevel gear production - even in an industrial serial process.
